Ana içeriğe geç
Samsung Galaxy Centura Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Centura Speaker Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Centura Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Speaker Replacement: adım 2, 3 resimden 1. Samsung Galaxy Centura Speaker Replacement: adım 2, 3 resimden 2. Samsung Galaxy Centura Speaker Replacement: adım 2, 3 resimden 3.
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Speaker Replacement, External Speaker: adım 3, 1 resimden 1.
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Speaker Replacement: adım 4, 1 resimden 1.
    • Gently insert the plastic opening tool into the notch on the side of the device. Apply a firm prying motion to pop open and remove the plastic casing.
  5. Samsung Galaxy Centura Speaker Replacement: adım 5, 2 resimden 1. Samsung Galaxy Centura Speaker Replacement: adım 5, 2 resimden 2.
    • Locate the black plastic clip at the top of the removed plastic casing. Use the metal spudger to release this clip.
    • Apply a firm prying motion to remove the pink plastic section. The external speaker is a part of this assembly.
Sonuç
Mohsen Alshammari
102 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 257
