Ana içeriğe geç
Samsung Galaxy Core Display Replacement
    1. Samsung Galaxy Core Display Replacement, Display: adım 1, 2 resimden 1. Samsung Galaxy Core Display Replacement, Display: adım 1, 2 resimden 2.
      • Turn the phone off
      • Remove the back cover
      • Extract battery
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Core Display Replacement: adım 2, 1 resimden 1.
      • Remove the 9 screws
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Core Display Replacement: adım 3, 1 resimden 1.
      • Remove the central frame to access the motherboard, help yourself with a thin tool
      • Remove the black screw that secures the lower motherboard
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Core Display Replacement: adım 4, 3 resimden 1. Samsung Galaxy Core Display Replacement: adım 4, 3 resimden 2. Samsung Galaxy Core Display Replacement: adım 4, 3 resimden 3.
      • Unclip the 3 connectors
      • Disconnect the connection cable of the 2 motherboards
      • With a flat instrument, help yourself to unhook the motherboard
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Core Display Replacement: adım 5, 3 resimden 1. Samsung Galaxy Core Display Replacement: adım 5, 3 resimden 2. Samsung Galaxy Core Display Replacement: adım 5, 3 resimden 3.
      • Remove top motherboard
      • Remove Speaker
      • Remove the lower motherboard with the help of a hot air hairdryer to help it detach from the adhesive
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy Core Display Replacement: adım 6, 2 resimden 1. Samsung Galaxy Core Display Replacement: adım 6, 2 resimden 2.
      • If the touch screen glass is broken, use tape to avoid injury
      • Disconnect the TouchScreen connector
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy Core Display Replacement: adım 7, 1 resimden 1.
      • Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
      • Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Galaxy Core Display Replacement: adım 8, 3 resimden 1. Samsung Galaxy Core Display Replacement: adım 8, 3 resimden 2. Samsung Galaxy Core Display Replacement: adım 8, 3 resimden 3.
      • Remove the display with thin tools, using heat to detach the fixing adhesive
      FixBot'a Sor
      Yorum Ekle
Sonuç
To Reassemble your device, Follow these instruction reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
12.359 İtibar
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 1,786
