Ana içeriğe geç
Samsung Galaxy Core Prime Back Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Core Prime Back Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Back Camera Replacement: adım 2, 1 resimden 1.
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Back Camera Replacement: adım 3, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Back Camera Replacement: adım 4, 2 resimden 1. Samsung Galaxy Core Prime Back Camera Replacement: adım 4, 2 resimden 2.
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Back Camera Replacement: adım 5, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: adım 6, 2 resimden 1. Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: adım 6, 2 resimden 2.
    • Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Back Camera Replacement: adım 7, 1 resimden 1.
    • Heat the frame with a heat gun or hair dryer until the adhesive is loose.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Back Camera Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    Satın Al
  9. Samsung Galaxy Core Prime Back Camera Replacement: adım 9, 2 resimden 1. Samsung Galaxy Core Prime Back Camera Replacement: adım 9, 2 resimden 2.
    • Disconnect the power ribbon on the left side of the phone either with your fingers or tweezers
  10. Samsung Galaxy Core Prime Back Camera Replacement: adım 10, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
  11. Samsung Galaxy Core Prime Back Camera Replacement: adım 11, 2 resimden 1. Samsung Galaxy Core Prime Back Camera Replacement: adım 11, 2 resimden 2.
    Metal Spudger
    $2.99
    Satın Al
    • Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adrian Sanchez
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 1,458
