Ana içeriğe geç
Samsung Galaxy Core Prime Home Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Core Prime Home Button  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Home Button  Replacement: adım 2, 1 resimden 1.
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Home Button  Replacement: adım 3, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Home Button  Replacement: adım 4, 2 resimden 1. Samsung Galaxy Core Prime Home Button  Replacement: adım 4, 2 resimden 2.
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Home Button  Replacement: adım 5, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Home Button  Replacement, Home Button: adım 6, 1 resimden 1.
    • Use your thumb to remove the sim card.
  7. Samsung Galaxy Core Prime Home Button  Replacement: adım 7, 2 resimden 1. Samsung Galaxy Core Prime Home Button  Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
  8. Samsung Galaxy Core Prime Home Button  Replacement: adım 8, 1 resimden 1.
    • Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
    • Take care when using these heating tools.
  9. Samsung Galaxy Core Prime Home Button  Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    Satın Al
  10. Samsung Galaxy Core Prime Home Button  Replacement: adım 10, 2 resimden 1. Samsung Galaxy Core Prime Home Button  Replacement: adım 10, 2 resimden 2.
    Satın Al
    • Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
  11. Samsung Galaxy Core Prime Home Button  Replacement: adım 11, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
  12. Samsung Galaxy Core Prime Home Button  Replacement: adım 12, 1 resimden 1.
    • Heat the sides of the screen with a heat gun or hair dryer.
  13. Samsung Galaxy Core Prime Home Button  Replacement: adım 13, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
    • Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
  14. Samsung Galaxy Core Prime Home Button  Replacement: adım 14, 1 resimden 1.
    • Use tweezers to remove the home button.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kate Vogel
187 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 1,354
