Ana içeriğe geç
Samsung Galaxy Core Prime Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: adım 2, 1 resimden 1.
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: adım 3, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: adım 4, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 4, 2 resimden 2.
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: adım 5, 1 resimden 1.
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: adım 6, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: adım 7, 1 resimden 1.
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: adım 8, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    Satın Al
  9. Samsung Galaxy Core Prime Screen Replacement: adım 9, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 9, 2 resimden 2.
    Satın Al
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: adım 10, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 10, 2 resimden 2.
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: adım 11, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
  12. Samsung Galaxy Core Prime Screen Replacement: adım 12, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: adım 13, 3 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 13, 3 resimden 2. Samsung Galaxy Core Prime Screen Replacement: adım 13, 3 resimden 3.
    iFixit Opening Tool
    $1.99
    Satın Al
  14. Samsung Galaxy Core Prime Screen Replacement: adım 14, 2 resimden 1. Samsung Galaxy Core Prime Screen Replacement: adım 14, 2 resimden 2.
    • Use tweezers to disconnect the digitizer.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Cody Coombs
257 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
What if the phone does not come back on after assembly
nfl.ny.la.313 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 2,514
