Giriş
This guide will enable you to replace the screen in case of broken glass, failure to respond, etc. You will need a heat gun, Phillips #00 screwdriver, iFixit opening tool, and tweezers. Take care when using dangerous tools.
Neye ihtiyacın var
Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
Bu adımda kullanılan alet:iFixit Opening Tool$1.99
Use the iFixit Opening Tool to lift the frame.
Use the iFixit Opening Tool to remove the mother board.
Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
Use a heat gun and an iFixit Opening Tool tool to separate the screen from the digitizer.
7 farklı kişi bu kılavuzu tamamladı.
