Ana içeriğe geç
Samsung Galaxy Core Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Core Screen Replacement, Screen: adım 1, 3 resimden 1. Samsung Galaxy Core Screen Replacement, Screen: adım 1, 3 resimden 2. Samsung Galaxy Core Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
  2. Samsung Galaxy Core Screen Replacement: adım 2, 2 resimden 1. Samsung Galaxy Core Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery.
    • If your phone has a SIM card or MicroSD card, remove them.
  3. Samsung Galaxy Core Screen Replacement: adım 3, 1 resimden 1.
    • Remove the 9 Phillips #00 screws from the mid-frame.
  4. Samsung Galaxy Core Screen Replacement: adım 4, 2 resimden 1. Samsung Galaxy Core Screen Replacement: adım 4, 2 resimden 2.
    • Use an opening pick to pry off the mid frame.
  5. Samsung Galaxy Core Screen Replacement: adım 5, 2 resimden 1. Samsung Galaxy Core Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the following ribbon cables from the motherboard:
    • The digitizer and LCD assembly.
    • Headphone Jack and Earpiece.
    • Daughter board flex cable.
    • Antenna connector.
  6. Samsung Galaxy Core Screen Replacement: adım 6, 3 resimden 1. Samsung Galaxy Core Screen Replacement: adım 6, 3 resimden 2. Samsung Galaxy Core Screen Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to remove the motherboard.
  7. Samsung Galaxy Core Screen Replacement: adım 7, 3 resimden 1. Samsung Galaxy Core Screen Replacement: adım 7, 3 resimden 2. Samsung Galaxy Core Screen Replacement: adım 7, 3 resimden 3.
    • Remove the single Phillips screw that secures the daughterboard.
    • Remove the daughterboard.
    • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
  8. Samsung Galaxy Core Screen Replacement: adım 8, 3 resimden 1. Samsung Galaxy Core Screen Replacement: adım 8, 3 resimden 2. Samsung Galaxy Core Screen Replacement: adım 8, 3 resimden 3.
    • Use an opening pick to remove the audio jack.
  9. Samsung Galaxy Core Screen Replacement: adım 9, 2 resimden 1. Samsung Galaxy Core Screen Replacement: adım 9, 2 resimden 2.
    • Disconnect the digitizer's ribbon cable.
  10. Samsung Galaxy Core Screen Replacement: adım 10, 1 resimden 1.
    • Push the earpiece mesh outwards to release it.
  11. Samsung Galaxy Core Screen Replacement: adım 11, 1 resimden 1.
    • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
    • Use an opening pick to break up the glue around the edges of the digitizer.
    • You may apply more heat if needed.
    • Remove the digitizer and any broken glass.
Sonuç
90 farklı kişi bu kılavuzu tamamladı.
ivan coene
3.006 İtibar
2 adet Kılavuz yazıldı
11Kılavuz Yorumları
yes, but where can I buy the screen replacement?
Roxannie - Yanıt
I bought it on Ebay...
ivan coene - Yanıt
Comment root galaxy core prime g361f android 5.1.1
soulaemen - Yanıt
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - Yanıt
Nor do they show how the new digitizer plugs in...
chris smith -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 117,121
