Ana içeriğe geç
Samsung Galaxy Express 3 Rear Camera Lens Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: adım 2, 3 resimden 1. Samsung Galaxy Express 3 Rear Camera Lens Replacement: adım 2, 3 resimden 2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: adım 2, 3 resimden 3.
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: adım 3, 1 resimden 1.
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: adım 4, 2 resimden 1. Samsung Galaxy Express 3 Rear Camera Lens Replacement: adım 4, 2 resimden 2.
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 565
