Ana içeriğe geç
Samsung Galaxy Fame S6812i Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: adım 1, 1 resimden 1.
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: adım 3, 3 resimden 1. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: adım 3, 3 resimden 2. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: adım 3, 3 resimden 3.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: adım 4, 2 resimden 1. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: adım 4, 2 resimden 2.
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: adım 5, 1 resimden 1.
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Charles
133 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,078
