Neye ihtiyacın var
Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
Using the plastic opening tool pry into the bezel to remove the mid-frame
Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
Once you have separated the mid-frame it should look like this.
Replace the old mid-frame with the new one and follow the steps in reverse.
Bir başkası bu kılavuzu tamamladı.
