Ana içeriğe geç
Samsung Galaxy Fame S6812i Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: adım 2, 3 resimden 1. Samsung Galaxy Fame S6812i Midframe Replacement: adım 2, 3 resimden 2. Samsung Galaxy Fame S6812i Midframe Replacement: adım 2, 3 resimden 3.
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: adım 3, 1 resimden 1.
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: adım 4, 2 resimden 1. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: adım 4, 2 resimden 2.
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: adım 5, 1 resimden 1.
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Charles
133 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 615
