Ana içeriğe geç
Samsung Galaxy Gear Display Housing Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Gear Display Housing Replacement, Display Housing: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Housing Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Housing Replacement: adım 3, 2 resimden 1. Samsung Galaxy Gear Display Housing Replacement: adım 3, 2 resimden 2.
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dalt Lasell
543 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G9
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 1,269
