Ana içeriğe geç
Samsung Galaxy Gear Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Gear Motherboard Replacement, Display Housing: adım 1, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Motherboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Gear Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Samsung Galaxy Gear Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
  5. Samsung Galaxy Gear Motherboard Replacement: adım 5, 1 resimden 1.
    • The motherboard is attached to the display using an adhesive
    • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
  6. Samsung Galaxy Gear Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Gear Motherboard Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
    • Slowly pry up the motherboard from the display.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joe
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G9
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Had to build a cradle, keep breaking, do not know out the 5 brass pronges which is pisitive and negative, how is there no schematic of the gear watch??
Chris martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 2,562
