Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide is needed if your midframe on your phone is broken or cracked.
  1. Remove the back cover of phone by lifting up on the back cover tab with  the blue plastic opening tool. Go around the edge of the back cover to completely remove it. Go around the edge of the back cover to completely remove it.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Remove the old battery by lifting up on  the thumb tab. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  5. Wedge the blue plastic opening tool in between the front and side panel. Move the blue plastic opening tool around the edges between the front and side panel.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  6. Make sure that you detach the mid-frame from the inside too. Make sure that you detach the mid-frame from the inside too.
    • Make sure that you detach the mid-frame from the inside too.
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Kyle Ruff
6.000 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G3
3 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
anyone can tell me how to swap vibrator motor?
Athaariq Ardiansyah Ramadhani - Yanıt
I need some glue to replace the midframe after having changed it?
Andrea Rossetti - Yanıt
not necessary
yasir -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 10,431
