Giriş
This guide is needed if your midframe on your phone is broken or cracked.
Neye ihtiyacın var
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
42 farklı kişi bu kılavuzu tamamladı.
3 Yorum
anyone can tell me how to swap vibrator motor?
I need some glue to replace the midframe after having changed it?
not necessary
yasir -
Thanks so much. I was getting seriously annoyed. This worked for me. However, I'll be getting another battery just in case. This helped big
Ana - Yanıt
