Ana içeriğe geç
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: adım 2, 3 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: adım 2, 3 resimden 2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: adım 2, 3 resimden 3.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: adım 4, 2 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: adım 4, 2 resimden 2.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: adım 5, 2 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: adım 5, 2 resimden 2.
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 2.
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Kyle Ruff
6.725 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G3
3 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - Yanıt
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - Yanıt
How to me a memory card a default storage on grand prime
Ayandaundetsco - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 35,969
