Ana içeriğe geç
Samsung Galaxy Grand Prime Micro USB Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: adım 2, 3 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: adım 2, 3 resimden 2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: adım 2, 3 resimden 3.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 4, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 4, 2 resimden 2.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 5, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 5, 2 resimden 2.
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 2.
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: adım 7, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: adım 7, 2 resimden 2.
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 8, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 8, 2 resimden 2.
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: adım 9, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: adım 9, 2 resimden 2.
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 10, 3 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 10, 3 resimden 2. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 10, 3 resimden 3.
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 11, 2 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement: adım 11, 2 resimden 2.
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: adım 12, 3 resimden 1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: adım 12, 3 resimden 2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: adım 12, 3 resimden 3.
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Kyle Ruff
6.725 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 34,768
