Ana içeriğe geç
Samsung Galaxy Grand Prime Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: adım 2, 3 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: adım 2, 3 resimden 2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: adım 2, 3 resimden 3.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement: adım 4, 2 resimden 2.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement: adım 5, 2 resimden 2.
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: adım 6, 2 resimden 2.
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: adım 7, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: adım 7, 2 resimden 2.
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Motherboard Replacement: adım 8, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Motherboard Replacement: adım 10, 3 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement: adım 10, 3 resimden 2. Samsung Galaxy Grand Prime Motherboard Replacement: adım 10, 3 resimden 3.
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Motherboard Replacement: adım 11, 2 resimden 1. Samsung Galaxy Grand Prime Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
Sonuç
86 farklı kişi bu kılavuzu tamamladı.
Kyle Ruff
6.725 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G3
3 Üyeler
12 adet Kılavuz yazıldı
12 Yorum
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - Yanıt
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair -
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - Yanıt
My grand prime 4g board damage
Rakesh - Yanıt
My grand prime 4g mother board damage
Rakesh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 53,092
