Ana içeriğe geç
Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: adım 1, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: adım 1, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: adım 1, 3 resimden 3.
    • Here we have Samsung Galaxy J1 with broken glass and screen.
    • We will replace the touch screen and the LCD.
    • First remove the battery and any installed SIM and memory cards.
  2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 2, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 2, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 2, 3 resimden 3.
    • Under this plastic is the LCD flex cable connector.
    • Use a tool with a needlepoint and remove it.
    is it posible to change only display my touch is allright
    Sa Bin Sth - Yanıt
  3. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 3, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 3, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 3, 3 resimden 3.
    • Disconnect the LCD flex cable.
    • When I can, I always test new replacement part before I install it.
  4. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 4, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 4, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 4, 3 resimden 3.
    • Use hot air to warm the glass and to make adhesive soften.
    • With a cutter or knife start the separation.
    • When you have enough space between the glass and the frame, continue with a plastic tool.
  5. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 5, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 5, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 5, 3 resimden 3.
    • You can warm the glass again to make the separation more easy.
    • If you want to change only the touch screen, be careful, don't break the LCD.
    • Finally remove the screen and the glass from the frame.
  6. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 6, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 6, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 6, 3 resimden 3.
    • If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
  7. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 7, 3 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 7, 3 resimden 2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 7, 3 resimden 3.
    • Connect the touch screen to the LCD flex cable.
    • Put the LCD and the screen in their place.
    • Remove the protector from the touch screen.
    • Install the earpiece metal plate - take it from the old touch screen.
    • Remove the protector from the LCD (if it's new).
  8. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 8, 2 resimden 1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: adım 8, 2 resimden 2.
    • Connect the LCD flex cable and you are ready.
    I put a new screen on the phone but when I turn it on the screen is still black with light up lines. What can I do to make the phone work
    Aleshia Te Slaa - Yanıt
    Where can I get the screen to buy… please
    Kingsley - Yanıt
Sonuç
113 farklı kişi bu kılavuzu tamamladı.
ZFix
191.182 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.521 adet Kılavuz yazıldı
24 Yorum
Bonjour, ou peux t on trouver l'écran et la vitre de protection ? Merci d'avance
Romain - Yanıt
How much is the cost for Galaxy J1 replacement glass?
Charles Young - Yanıt
It costs from 18€ up to 25€.
Johannes Franzen -
Gracias bro .. se ve interesante el único problema es que no se muy bien el ingles
Luis Fernando Ibarra casquete - Yanıt
LCD was saved and I replaced the touch and I put a new one and display was black what will be the issue solve it plzzzz
waqar - Yanıt
Awesome video, can you bring me a link for the touchscreen part? mi lcd its OK, but the glass is broken, im not sure wich one should i buy
christian - Yanıt
Hello!Need wholesale LCD screen?https://txlcd.com/
txlcdsupplier - Yanıt
Samnsung j1 SM-j111M
Richard Moya - Yanıt
I can't find replacemnt for Samnsung j1 SM-j111M?
do you know what model it is compatible with it?
Not charge contineu
sanu_197415 - Yanıt
How much is the touchscreen part for SM-J120H in Peso?
Andrew - Yanıt
Why is it that replacing the touch and LCD is so expensive
Chris pine ochieng - Yanıt
dear sir,
your thing is good but you have to work a lot on ending because it is most important part .So i hope you you improve it for others.
your faithful
krishna kedia
krishna - Yanıt
I want to do a full screen replacement , internal LCD and outer LCD.
Where do I order the LCD Screen . SM-J100Y
ISHMAEL - Yanıt
I have put a new screen on my friends Samsung galaxy J1 but it won't turn on and when it dose I'll see are lines. What do I do?
Very helpful, thank you!
Jess Price - Yanıt
Obrigado, primeiro conserto realizado.
David - Yanıt
Is J1 LCD is compatible with J1 Ace model J110H ?
Arpit Moriya - Yanıt
Samsung j1ace full screen replacement
erick kuyanda - Yanıt
where in Papua New Guinea can I buy new Samsung Galaxy glass screen?
Michael - Yanıt
how much price of touch screen in indian rupee?
roshan - Yanıt
thank for posting, genial consejo
harkhoscole - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 71
Her zaman: 148,087
