Ana içeriğe geç
Samsung Galaxy J1 Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: adım 1, 1 resimden 1.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: adım 2, 2 resimden 1. Samsung Galaxy J1 Midframe Replacement: adım 2, 2 resimden 2.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: adım 4, 3 resimden 1. Samsung Galaxy J1 Midframe Replacement: adım 4, 3 resimden 2. Samsung Galaxy J1 Midframe Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Sean Kramer
1.452 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 2,092
