Ana içeriğe geç
Samsung Galaxy J1 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: adım 1, 1 resimden 1.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: adım 2, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy J1 Motherboard Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: adım 8, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: adım 9, 3 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 9, 3 resimden 2. Samsung Galaxy J1 Motherboard Replacement: adım 9, 3 resimden 3.
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: adım 10, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: adım 11, 2 resimden 1. Samsung Galaxy J1 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the rear camera.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Sean Kramer
1.452 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G4
3 Üyeler
4 Yorum
can you plz give use a amazon link to part
Sean Gynn - Yanıt
Very good illustration..where can I get a motherboard?
Isaac Samuels - Yanıt
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
FUN FIRST - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 6,632
