Ana içeriğe geç
Giriş
Use this guide to replace the Rear Camera.
  1. Insert a finger nail or plastic opening tool between the back cover and the device.
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Using a finger, pull the SIM card down out of its slot. Remove the SIM card.
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. Insert a plastic opening tool between the screen and the back of the device. Starting at the bottom of the device, gently slide the tool along the edges of the screen. Gently pry the main assembly from the midframe of the device.
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  6. Use the flat end of a spudger to disconnect the ear speaker connector from the motherboard. Use the flat end of a spudger to disconnect the ear speaker connector from the motherboard.
    • Use the flat end of a spudger to disconnect the ear speaker connector from the motherboard.
  7. Use the flat end of a spudger to disconnect the digitizer connector from the motherboard. Use the flat end of a spudger to disconnect the digitizer connector from the motherboard.
    • Use the flat end of a spudger to disconnect the digitizer connector from the motherboard.
  8. Use a plastic opening tool to gently pry under the motherboard. Remove motherboard. Remove motherboard.
    • Use a plastic opening tool to gently pry under the motherboard.
    • Remove motherboard.
  9. Use the flat end of a spudger to disconnect the rear camera from the motherboard. Remove the rear camera. Remove the rear camera.
    • Use the flat end of a spudger to disconnect the rear camera from the motherboard.
    • Remove the rear camera.
Sonuç
Sean Kramer
1.071 İtibar
6 adet Kılavuz yazıldı
Takım
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 7
Son 30 Gün: 46
Her zaman: 532
