Ana içeriğe geç
Samsung Galaxy J3 Eclipse Audio Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Eclipse Audio Jack Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the phone face down on its screen.
  2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 2, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 2, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 2, 3 resimden 3.
    • Pull up on the small indention on the right side edge and remove the back portion of the phone.
  3. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 3, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 3, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 3, 3 resimden 3.
    • After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
  4. Samsung Galaxy J3 Eclipse Audio Jack Replacement, Display Assembly: adım 4, 1 resimden 1.
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  5. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 5, 2 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  6. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 6, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 6, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 6, 3 resimden 3.
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  7. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 7, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 7, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 7, 3 resimden 3.
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  8. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 8, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 8, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 8, 3 resimden 3.
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
  9. Samsung Galaxy J3 Eclipse Audio Jack Replacement, Audio Jack: adım 9, 3 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement, Audio Jack: adım 9, 3 resimden 2. Samsung Galaxy J3 Eclipse Audio Jack Replacement, Audio Jack: adım 9, 3 resimden 3.
    • Locate all eleven screws attaching the metal plate to the frame, and remove them using a PH00 screwdriver bit.
    • Keep track of the eleven screws they are essential to close the phone back again.
  10. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 10, 2 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 10, 2 resimden 2.
    • While holding the phone , flip it to the back side and use your two thumbs to push on the metal area where the battery was, this should release the back frame from the device.
  11. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 11, 2 resimden 1. Samsung Galaxy J3 Eclipse Audio Jack Replacement: adım 11, 2 resimden 2.
    • Locate the blue ribbon cable attached just below the battery slot . This is the connector for your audio jack.
    • Use your pry tool to release the cable from the motherboard
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 855
