Giriş
This guide will help you fix a broken or shattered screen on your Samsung J3 device.
Neye ihtiyacın var
Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
Bu adımda kullanılan alet:Plastic Cards$2.99
While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
To reassemble your device, connect all cables, apply fresh screen adhesive and follow these instructions in reverse order.
12 farklı kişi bu kılavuzu tamamladı.
