Ana içeriğe geç
Samsung Galaxy J3 Emerge Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Emerge Camera Replacement, Screen: adım 1, 3 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement, Screen: adım 1, 3 resimden 2. Samsung Galaxy J3 Emerge Camera Replacement, Screen: adım 1, 3 resimden 3.
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Camera Replacement: adım 2, 2 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement: adım 2, 2 resimden 2.
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Camera Replacement: adım 3, 2 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement: adım 3, 2 resimden 2.
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
  4. Samsung Galaxy J3 Emerge Camera Replacement, Motherboard: adım 4, 2 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the eleven Phillips #00 3.5mm screws.
    • If the screws get stuck when removing, try using tape to get them out. Place the adhesive side of tape on the screws and pull the tape off the spot.
  5. Samsung Galaxy J3 Emerge Camera Replacement: adım 5, 1 resimden 1.
    • Turn the phone over and push down where the battery was.
    • There will be a loud clicking noise when applying pressure.
  6. Samsung Galaxy J3 Emerge Camera Replacement: adım 6, 1 resimden 1.
    • Insert the iFixit Opening Pick between the motherboard and the panel.
    • Work the iFixit Opening Pick around the outside of the motherboard.
  7. Samsung Galaxy J3 Emerge Camera Replacement: adım 7, 2 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement: adım 7, 2 resimden 2.
    • Pry the motherboard away from the phone using your hand.
  8. Samsung Galaxy J3 Emerge Camera Replacement, Camera: adım 8, 1 resimden 1.
    • Pull the green tape over the connectors off.
  9. Samsung Galaxy J3 Emerge Camera Replacement: adım 9, 1 resimden 1.
    • Lift up the tabs to reveal the ribbons.
  10. Samsung Galaxy J3 Emerge Camera Replacement: adım 10, 2 resimden 1. Samsung Galaxy J3 Emerge Camera Replacement: adım 10, 2 resimden 2.
    • Pull the two camera ribbons away from the connectors.
Sonuç
Hugh Cosculluela
507 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G2, White Winter 2019 Cal Poly, Team S19-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S19G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 563
