Ana içeriğe geç
Samsung Galaxy J3 Home Key Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Home Key Replacement, Home Key: adım 1, 1 resimden 1.
    • Separate the back casing from the phone by carefully using your fingers to pry them apart.
  2. Samsung Galaxy J3 Home Key Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Samsung Galaxy J3 Home Key Replacement: adım 3, 1 resimden 1.
    • Remove all ten screws by using a Phillips #000 screwdriver.
  4. Samsung Galaxy J3 Home Key Replacement: adım 4, 1 resimden 1.
    • Use the flat side of a spudger to remove the middle frame bezel.
    • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
  5. Samsung Galaxy J3 Home Key Replacement: adım 5, 1 resimden 1.
    • Gently pull the glass up from the side of the phone and push the home button out.
    • When you pull the glass up, it will make a popping sound. This is normal.
  6. Samsung Galaxy J3 Home Key Replacement: adım 6, 1 resimden 1.
    • Replace the home button and press the glass back in place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - Yanıt
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 2,707
