Ana içeriğe geç
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 2, 3 resimden 1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 2, 3 resimden 2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 2, 3 resimden 3.
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 3, 3 resimden 1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 3, 3 resimden 2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 3, 3 resimden 3.
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 4, 3 resimden 1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 4, 3 resimden 2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 4, 3 resimden 3.
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 5, 3 resimden 1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 5, 3 resimden 2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: adım 5, 3 resimden 3.
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: adım 6, 2 resimden 1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: adım 6, 2 resimden 2.
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Mendoza
646 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Passmore Spring 2018 USF Tampa, Team S5-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,197
