Ana içeriğe geç
Giriş
If you ever find yourself in a scenario where you have a completely normal phone and then out of nowhere it ceases to operate. It may be time for a motherboard change. This guide will provide the step by step process of switching the processing component of the Samsung Galaxy J3 Luna Pro.
  1. Turn off the phone.
    • Turn off the phone.
    • Remove the back cover and battery
  2. Attach a suction cup to the screen and pry upwards. Insert the plastic opening tool into the gap under the screen and work your way around the perimeter. Don't remove the screen completely as there are cables still connection the two pieces.
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Use the pointy end of a spudger to remove the white plastic cover from the display cover. Use the spudger to pry up the display cable from the motherboard. Remove the screen.
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  5. Remove the eleven JIS 00 screws from the mid-frame. Using a spudger, pry the mid-frame from the screen. Using a spudger, pry the mid-frame from the screen.
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  6. Remove the motherboard from the mid-frame. Remove the motherboard from the mid-frame. Remove the motherboard from the mid-frame.
    • Remove the motherboard from the mid-frame.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
shima1h
161 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team S5-G5, Passmore Spring 2018 USF Tampa, Team S5-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G5
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 11
Son 30 Gün: 98
Her zaman: 1,011
