Ana içeriğe geç
Samsung Galaxy J3 Mission Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Mission Midframe Replacement, Back Cover: adım 1, 1 resimden 1.
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Midframe Replacement, Battery: adım 2, 1 resimden 1.
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Midframe Replacement, SD and SIM Cards: adım 3, 1 resimden 1.
    • Use your finger to slide the SD and SIM card out of the device.
  4. Samsung Galaxy J3 Mission Midframe Replacement, Screen: adım 4, 1 resimden 1.
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
  5. Samsung Galaxy J3 Mission Midframe Replacement, Midframe: adım 5, 2 resimden 1. Samsung Galaxy J3 Mission Midframe Replacement, Midframe: adım 5, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove all eleven 5mm screws from the metal panel.
  6. Samsung Galaxy J3 Mission Midframe Replacement: adım 6, 1 resimden 1.
    • Turn the device over, and push firmly to separate the metal plate from the back paneling.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 496
