Ana içeriğe geç
Samsung Galaxy J3 Mission Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3 Mission Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Screen Replacement, Battery: adım 2, 1 resimden 1.
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Screen Replacement, Screen: adım 3, 1 resimden 1.
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
Sonuç
To install a new screen try the connector before adding any adhesive, then put it back together by following these steps in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 17
Her zaman: 1,930
