Ana içeriğe geç
Samsung Galaxy J3V Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3V Front Camera Replacement, Front Camera: adım 1, 3 resimden 1. Samsung Galaxy J3V Front Camera Replacement, Front Camera: adım 1, 3 resimden 2. Samsung Galaxy J3V Front Camera Replacement, Front Camera: adım 1, 3 resimden 3.
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Front Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy J3V Front Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy J3V Front Camera Replacement: adım 2, 3 resimden 3.
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Front Camera Replacement: adım 3, 3 resimden 1. Samsung Galaxy J3V Front Camera Replacement: adım 3, 3 resimden 2. Samsung Galaxy J3V Front Camera Replacement: adım 3, 3 resimden 3.
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Front Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy J3V Front Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy J3V Front Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to flip tab of the front camera to remove it.
Sonuç
Carry Corrales
792 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Nance Fall 2017 USF Tampa, Team S3-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 541
