Ana içeriğe geç
Samsung Galaxy J3V Headphone Jack Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 1. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 2. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 3.
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Headphone Jack Replacement: adım 2, 3 resimden 1. Samsung Galaxy J3V Headphone Jack Replacement: adım 2, 3 resimden 2. Samsung Galaxy J3V Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Headphone Jack Replacement: adım 3, 3 resimden 1. Samsung Galaxy J3V Headphone Jack Replacement: adım 3, 3 resimden 2. Samsung Galaxy J3V Headphone Jack Replacement: adım 3, 3 resimden 3.
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Headphone Jack Replacement: adım 4, 3 resimden 1. Samsung Galaxy J3V Headphone Jack Replacement: adım 4, 3 resimden 2. Samsung Galaxy J3V Headphone Jack Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove connector tab with spudger then carefully remove headphone jack with tweezers.
Sonuç
Carry Corrales
738 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Nance Fall 2017 USF Tampa, Team S3-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 567
