Ana içeriğe geç
Samsung Galaxy J6 Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 2. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 3.
    • I recommend wearing eye protection to avoid any inconvenience with glass fragments.
    • It is very important to heat the display on the side parts where the double-sided adhesive is well with a hairdryer or other so as to make it lose its adhesion and facilitate the operation of inserting the blade to lift it.
    • Insert the blade between the body and the glass and begin to separate the display from the body, I recommend starting from the top paying attention.
    • The flat connection connectors are located at the bottom.
  2. Samsung Galaxy J6 Display Replacement, Lift up the display: adım 2, 2 resimden 1. Samsung Galaxy J6 Display Replacement, Lift up the display: adım 2, 2 resimden 2.
    • Lift the display.
  3. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 1. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 2. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 3.
    • Unplug the black plastic plug securing the display connector.
    • Unhook the display connector.
    • Remove the old display and place the new display.
    • Put some glue to attach the new display.
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
11.267 İtibar
39 adet Kılavuz yazıldı
10 Yorum
f**k this adhesive!!
Thanks for this tutorial :)
NoCheatImPGM - Yanıt
Gli adesivi non aderiscono bene sono d’accordo,puoi provare con altro biadesivo 3M oppure con della colla idonea.
Smilzo -
You mentioned nothing about disconnecting the battery. If the phone accidentally turns on in the middle of a display swap [with no way to turn it off, since there’s no display or digitser connected] you will blow an internal fuse, rendering the phone useless. Complete waste of time! You should have included that the battery be disconnected before attempting this.
Dot - Yanıt
Ciao ti ringrazio per la Puntualizzazione ed il buon consiglio.
io non ho mai avuto problemi nello scollegare i display perché il telefono è precedentemente spento e rimane spento fino a quando non scollego il connettore display.
se per sfortuna si dovesse toccare il tasto power (che comunque richiede una lunga pressione e non un semplice tocco ) si vedrebbe accendere il display o vibrare il telefono o accendersi i led. Quindi prima di scollegare lo spegnerei nuovamente.
non vedo il problema.
scollegare la batteria comporta una procedura analoga a togliere il display e quindi molto tempo in più ed accollarsi i rischi di rompere un componente posteriore per rimuoverlo,perdendo così impermeabilità se non si dispone di adesivo specifico per questa sostituzione.
Smilzo -
Ciao e grazie della guida.
Quale modello di display e su quale sito consigli di comprarlo?
Danilo B. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 85
Son 30 gün: 210
Her zaman: 15,346
