Giriş
This guide shows how to replace the battery of a Samsung Galaxy J7.
Neye ihtiyacın var
Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
Remove Battery: Gently pop out the edge and carefully pull out the battery.
11 farklı kişi bu kılavuzu tamamladı.
