Ana içeriğe geç
Samsung Galaxy J7 Front Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy J7 Front Facing Camera Replacement, Back Cover: adım 1, 2 resimden 2.
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Front Facing Camera Replacement, Midframe: adım 2, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  3. Samsung Galaxy J7 Front Facing Camera Replacement: adım 3, 3 resimden 1. Samsung Galaxy J7 Front Facing Camera Replacement: adım 3, 3 resimden 2. Samsung Galaxy J7 Front Facing Camera Replacement: adım 3, 3 resimden 3.
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
  4. Samsung Galaxy J7 Front Facing Camera Replacement, Front Facing Camera: adım 4, 1 resimden 1.
    • Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
  5. Samsung Galaxy J7 Front Facing Camera Replacement: adım 5, 1 resimden 1.
    • Make sure to pull up all of these parts in order to properly take off the next piece.
  6. Samsung Galaxy J7 Front Facing Camera Replacement: adım 6, 2 resimden 1. Samsung Galaxy J7 Front Facing Camera Replacement: adım 6, 2 resimden 2.
    • Pull the blue/green piece away from the black piece. They should not need any force to be removed. The next step will deal with using the green/blue piece from the second picture.
  7. Samsung Galaxy J7 Front Facing Camera Replacement: adım 7, 2 resimden 1. Samsung Galaxy J7 Front Facing Camera Replacement: adım 7, 2 resimden 2.
    • Flip over the piece (180 degrees). Remove the boxed out piece. This is the front facing camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 59
Her zaman: 514
