Ana içeriğe geç
Samsung Galaxy J7 Midframe Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 Midframe Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy J7 Midframe Replacement, Back Cover: adım 1, 2 resimden 2.
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Midframe Replacement, Battery: adım 2, 2 resimden 1. Samsung Galaxy J7 Midframe Replacement, Battery: adım 2, 2 resimden 2.
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
  3. Samsung Galaxy J7 Midframe Replacement, Midframe: adım 3, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  4. Samsung Galaxy J7 Midframe Replacement: adım 4, 3 resimden 1. Samsung Galaxy J7 Midframe Replacement: adım 4, 3 resimden 2. Samsung Galaxy J7 Midframe Replacement: adım 4, 3 resimden 3.
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 40
Her zaman: 1,360
