Ana içeriğe geç
Samsung Galaxy J7 Screen Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy J7 Screen Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Screen Assembly Replacement, Battery: adım 2, 2 resimden 1. Samsung Galaxy J7 Screen Assembly Replacement, Battery: adım 2, 2 resimden 2.
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
  3. Samsung Galaxy J7 Screen Assembly Replacement, Midframe: adım 3, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
  4. Samsung Galaxy J7 Screen Assembly Replacement: adım 4, 3 resimden 1. Samsung Galaxy J7 Screen Assembly Replacement: adım 4, 3 resimden 2. Samsung Galaxy J7 Screen Assembly Replacement: adım 4, 3 resimden 3.
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
  5. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: adım 5, 2 resimden 1. Samsung Galaxy J7 Screen Assembly Replacement, Screen Assembly: adım 5, 2 resimden 2.
    • The speaker piece is lightly adhered. Use a plastic pry tool to gently lift it up and disconnect the cable.
  6. Samsung Galaxy J7 Screen Assembly Replacement: adım 6, 2 resimden 1. Samsung Galaxy J7 Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Gently lift up the tab of the motor.
    • Remove the motor from the panel completely to disconnect it.
    • Removing the motor allows easier access to the screen assembly for replacement. Handle the motor and its connectors with care.
  7. Samsung Galaxy J7 Screen Assembly Replacement: adım 7, 1 resimden 1.
    • Reverse these steps with your new phone screen to replace it.
    • After reassembly, test the new screen for touch responsiveness and display quality before fully securing the device
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
I replaced the broken screen....before I saw this. Now my phone will not turn on. what should I do? ruth.fnp@gmail.com
Ruth Thomas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 73
Her zaman: 11,737
