Ana içeriğe geç
Samsung Galaxy J7 V Power Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 V Power Button Replacement, Screen: adım 1, 1 resimden 1.
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Power Button Replacement: adım 2, 1 resimden 1.
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Power Button Replacement: adım 3, 1 resimden 1.
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Power Button Replacement, Home button: adım 4, 1 resimden 1.
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Power Button Replacement: adım 5, 1 resimden 1.
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Power Button Replacement, Volume Button: adım 6, 2 resimden 1. Samsung Galaxy J7 V Power Button Replacement, Volume Button: adım 6, 2 resimden 2.
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 V Power Button Replacement: adım 7, 1 resimden 1.
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 V Power Button Replacement: adım 8, 2 resimden 1. Samsung Galaxy J7 V Power Button Replacement: adım 8, 2 resimden 2.
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 V Power Button Replacement: adım 9, 3 resimden 1. Samsung Galaxy J7 V Power Button Replacement: adım 9, 3 resimden 2. Samsung Galaxy J7 V Power Button Replacement: adım 9, 3 resimden 3.
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 V Power Button Replacement: adım 10, 3 resimden 1. Samsung Galaxy J7 V Power Button Replacement: adım 10, 3 resimden 2. Samsung Galaxy J7 V Power Button Replacement: adım 10, 3 resimden 3.
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
  11. Samsung Galaxy J7 V Power Button Replacement, Power Button: adım 11, 2 resimden 1. Samsung Galaxy J7 V Power Button Replacement, Power Button: adım 11, 2 resimden 2.
    • Use the metal spudger tool to lift the metal bar holding the button in place.
  12. Samsung Galaxy J7 V Power Button Replacement: adım 12, 1 resimden 1.
    • Use the metal spudger tool to push on the power button to remove it from the phone.
Sonuç
To reassemble your device, follow these instructions in reverse order. Please don't miss a screw!
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Abi benim power ve home tuşu çıkmıştı ya ona bir tane yapabilir misin takabilir misin Neredesiniz konumu at ben gelirim
Benim home tuşu çıkmış - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 68
Her zaman: 3,690
