Ana içeriğe geç
Samsung Galaxy J7 V Rear Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 V Rear Camera Replacement, Screen: adım 1, 1 resimden 1.
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Rear Camera Replacement: adım 2, 1 resimden 1.
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Rear Camera Replacement: adım 3, 1 resimden 1.
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Rear Camera Replacement, Home button: adım 4, 1 resimden 1.
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Rear Camera Replacement: adım 5, 1 resimden 1.
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: adım 6, 2 resimden 1. Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: adım 6, 2 resimden 2.
    • Use the indent on the right side of the phone to lift up the backing
    • With the phone faced downwards, remove the backing of the case, lifting up from the right side
  7. Samsung Galaxy J7 V Rear Camera Replacement, Remove the battery: adım 7, 1 resimden 1.
    • Carefully remove the battery by lifting the bottom side, and then fully remove the battery
  8. Samsung Galaxy J7 V Rear Camera Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
  9. Samsung Galaxy J7 V Rear Camera Replacement: adım 9, 1 resimden 1.
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
  10. Samsung Galaxy J7 V Rear Camera Replacement: adım 10, 2 resimden 1. Samsung Galaxy J7 V Rear Camera Replacement: adım 10, 2 resimden 2.
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
  11. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: adım 11, 3 resimden 1. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: adım 11, 3 resimden 2. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to detach the tab securing the rear camera.
    • Use your fingers to pull the camera away from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
goood
شكرا كتير لقد استفت من الموقع جدا واتمنى ان اواصل معرفه واطلاع على كل جديد
ageedaa11 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 606
