Ana içeriğe geç
Samsung Galaxy J7 Volume Button Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J7 Volume Button Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Galaxy J7 Volume Button Replacement, Back Cover: adım 1, 2 resimden 2.
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
  2. Samsung Galaxy J7 Volume Button Replacement, Volume Button: adım 2, 1 resimden 1.
    • Once your device's back has been disassembled, grab the panel that has the volume buttons.
  3. Samsung Galaxy J7 Volume Button Replacement: adım 3, 1 resimden 1.
    • Turn the panel around and locate the volume button.
  4. Samsung Galaxy J7 Volume Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the rubber tabs and gently lift them up from their inserts with the tweezers.
  5. Samsung Galaxy J7 Volume Button Replacement: adım 5, 1 resimden 1.
    • Push button inward from the outside to remove.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 41
Her zaman: 1,433
