Ana içeriğe geç
Samsung Galaxy Light Earpiece Speaker Replacement
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: adım 2, 1 resimden 1.
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: adım 4, 1 resimden 1.
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: adım 5, 3 resimden 3.
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: adım 6, 2 resimden 1. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: adım 6, 2 resimden 2.
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Paul Goyette
466 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 652
