Ana içeriğe geç
Giriş
Replace the motherboard on your Samsung Galaxy Light.
Parçalar
Hiçbir parça belirtilmedi.
  1. Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Remove the battery from the device.
    • Remove the battery from the device.
  3. Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. To detach the motherboard from the device: Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard. Carefully lift the motherboard up and move it toward the left side of the device.
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Diandra
198 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,029
