Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace the motherboard on your Samsung Galaxy Light.
Neye ihtiyacın var
Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
Remove the back cover.
Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
Using the plastic opening tool, separate the midframe from the front panel of the device.
Remove the midframe.
To detach the motherboard from the device:
Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
Carefully lift the motherboard up and move it toward the left side of the device.
Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
7 farklı kişi bu kılavuzu tamamladı.
