Ana içeriğe geç
Samsung Galaxy Light Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Battery: adım 2, 1 resimden 1.
    • Remove the battery from the device.
  3. Samsung Galaxy Light Rear Facing Camera Replacement, Unscrew Midframe: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Midframe: adım 4, 1 resimden 1.
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: adım 5, 3 resimden 3.
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 1 resimden 1.
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
91.167 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 573
