Ana içeriğe geç
Samsung Galaxy Light USB Charging Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: adım 2, 1 resimden 1.
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: adım 3, 1 resimden 1.
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: adım 4, 3 resimden 1. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: adım 4, 3 resimden 2. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: adım 4, 3 resimden 3.
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: adım 5, 2 resimden 1. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: adım 5, 2 resimden 2.
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Diandra
210 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G2
3 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - Yanıt
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - Yanıt
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,116
