Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Outline what you are going to teach someone how to do.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the back cover with the opening tool to reveal the battery
    • Remove the back cover with the opening tool to reveal the battery
  2. Now remove the battery and keep it somewhere safe for now
    • Now remove the battery and keep it somewhere safe for now
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Unscrew the nine screws shown with the Philips #0 screwdriver
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  5. You must detach and replace the entire motherboard the replace the charging port Slowly lift the motherboard up to pull it off the orange strip Pull slowly, you do not want to break this strip
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  6. Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard Make sure you line it up correctly with the orange strip
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Diandra
198 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G2
3 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - Yanıt
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - Yanıt
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 933
