Ana içeriğe geç
Samsung Galaxy Mega 2 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega 2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before begining, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once you get the corner released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Battery Replacement: adım 2, 2 resimden 1. Samsung Galaxy Mega 2 Battery Replacement: adım 2, 2 resimden 2.
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on bottom of the battery and gently lift up.
    • Remove the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 1,442
