Ana içeriğe geç
Samsung Galaxy Mega 2 Front Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega 2 Front Facing Camera Replacement, Front Facing Camera: adım 1, 1 resimden 1.
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 2, 2 resimden 1. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 2, 2 resimden 2.
    • Locate the battery.
    • Use pry tool or fingernail to lift up on the battery.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 3, 3 resimden 1. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 3, 3 resimden 2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use phillips head PH000 and remove all 13, 1.4 mm screws as shown.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use tweezers to disconnect the digitizer.
  4. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 4, 3 resimden 3.
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off, completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
  5. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 5, 3 resimden 1. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 5, 3 resimden 2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: adım 5, 3 resimden 3.
    • Locate the camera in the top left corner.
    • Lift the motherboard connector and remove the camera assembly from phone.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 801
