Ana içeriğe geç
Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: adım 1, 1 resimden 1.
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 2, 2 resimden 1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 2, 2 resimden 2.
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 3, 3 resimden 1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 3, 3 resimden 2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 3, 3 resimden 3.
    • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 4, 2 resimden 2.
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: adım 5, 1 resimden 1.
    • Now, seperate the screen from the outside frame of the phone (the bezel).
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
I want to repair my phone
Monirul Islam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 1,391
