Ana içeriğe geç
Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: adım 1, 3 resimden 1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: adım 1, 3 resimden 2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 2, 3 resimden 1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 2, 3 resimden 2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 2, 3 resimden 3.
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: adım 3, 3 resimden 1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: adım 3, 3 resimden 2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 4, 2 resimden 1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 4, 2 resimden 2.
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Earpiece Speaker/LED Indicator: adım 5, 1 resimden 1.
    • Remove the black 2.55 mm Phillips #000 screw.
  6. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 6, 1 resimden 1.
    • Remove the metal cover with the plastic opening tool.
  7. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 7, 2 resimden 1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard clip from speaker assembly to the motherboard.
    • Gently lift the speaker and LED assembly out of the device.
    • Speaker assembly may be glued to the device, gently pry until it releases.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Max Rathman
915 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,052
